1939 Hudson 112 Rear Hub puller
PaulButler
Administrator
What is the recommended type of puller to get the rear hubs of my 112?
I see in the owners manual that it says "NOTE-A SPECIAL WHEEL PULLER IS NECESSARY TO REMOVE THE HUBS. UNDER NO CONDITIONS SHOULD A KNOCK-OUT TYPE PULLER BE USED, OR THE AXLE END STRUCK A HEAVY BLOW AS THIS MIGHT DAMAGE THE
DIFFERENTIAL"
All help / suggestions gratefully received of course!
DIFFERENTIAL"
I have a hub puller for sale in the Parts and pieces section of this forum0
Thanks Ken ; looks as if one of those is now winging its way to me!
@lostmind ; thanks for the heads-up but I'm in the UK so postage would have been quite expensive0
