gas tank gauge sealing
I have installed a new gas sending unit. have attempted to seal it twice without any luck . thought I would ask here if there
is a secret to sealing to sealing them not sure this time weather it is leaking at gasket or thru electrical post
any ideas appreciated. this is a 53 stepdown
steve
steve
Ken,I'm going from memory here but I don't think that the screw holes go all the way through the tank. I think they only screw into the flange.John Forkner0
John...all sorts of differences exist in the HUDSON parts world.Recently I removed, renewed and re installed the fuel tank for my 54 Wasp Club Sedan. During that process I installed a new fuel gauge sending unit. I manufactured a cork gasket for the sending unit and replaced the original screws with key head screws. My tank did in fact have threaded holes that penetrate the tank fuel gauge sender mounting flange. As previously recommended, the cork gasket and the threads of the screws were sealed with Permatex.Personally, I have NO experience with the sender or mounting screws leaking, but have had two occasions where the pickup tube solder joint cracked where it penetrated the mounting reinforcement. When ever the tank was full, fuel leaked from that point.0
My Hudson Jet made a unilateral statement that the gasket had done it's dash, and started leaking from around the pick-up fitting whenever the tank was full. You would think they would fit a gasket that would last longer than 60 years surely? Luckily on the Jet both the pick-up and sender unit are accessible without dropping the tank. The sender unit also decided that it would develop a resistance between the connection and the body, and would only register 3/4 full. The resistance was only 10 ohms difference. I had to drill out the rivets and clean the surfaces and re-rivet back together.0
thanks guys for info
Steve0
- 104 Essex Super 6
