Unable to delete or edit attached files
Kdancy
I could edit the message but not the attached files.
You can't edit an attached file. About all you can do is delete them. What I would recommend is to delete the attachment(s) in question, make the changes (whatever they are) on your local copy, and re-post the attachments.0
Rick, I tried that right off the bat. every time I try it I get an error message.0
What is the thread?
306344 camshaft just profiled.
I need to remove the first and second attachment. Wrong camshaft number.0 -
Found it - can't delete the attachments either (?). Something that needs to be looked-into...
http://openforum.hetclub.org/discussion/166655/306344-camshaft-just-profiled#latest
Kerry, I just checked your post (the one with the attachments) and each one of the attachments has a blue "DELETE" button on it. Do yo want me to delete all the attachments, or save the one that's a photo?
(Maybe Aaron has noticed this problem and fixed it, thus the appearance of the DELETE option all of a sudden!)
Jon, delete the very first profile and the cam picture.
When I get the results of the "742" cam back, I'd like to add them to the post so all info would be on one post but don't see a way to do that now.0 -
Kerry, I'm sorry. When I pushed the "DELETE" button I got an error messae!
I didn't realize this would happen, when I first noticed the presence of the DELETE buttons; just assumed they'd work!
I've reported this to The Higher-Ups.
Meanwhile, why not simply remove the entire thread and post new photos? Or can you not do that, either?
I will continue to try and troubleshoot next week. I dont want to risk taking the site down or screwing with the FileUpload extension until I get back. Just don't upload any pictures that you would want to take down quickly. : ) Jon, this means no nude sunbathing pictures of yourself on the forum. If that happens folks may be begging me to take the site down!!Aaron0
Awww......not even ONE, Aaron?
