Rubber seal around doors
I'm not sure, but if you check with Wildrick Rubber they would be able to tell you if they're making this rubber. I thought that the "seals" of this era, were simply the fabric-wrapped windlace that finished off the edges of the upholstery at the door openings, inside.
In the old KGap book, it says no 1935 G, and no 1936 model 61. I assume its what Jon has said above.0
