Needed: A Broken Harmonic balancer
How about someone breaking one? LOL!
Shameless bump to the top
Dave , I've get them but none are broken.0
Dave,
I have a few broken ones.......no, I didn't break them. If I told you the story, I'd get so pissed that I wouldn't be able to finish this post. I'd like to keep the hub and rubber discs if you can still use your originals.
Frank0 -
Frank,
I'll need the whole thing..What I want to do, is grind the outer flange off and bolt on Cheby a double sheave to make a dual belt pulley. I've done it twice but I had two busted ones to use. I just hate to destroy a good usable original part.
I have one that I just took off a 262 that was worn and locked up so bad it wasn't worth trying to take more of it apart. You can have that one for the shipping.
hetcramerlp@roadrunner.com and do the delete
Whilst on the subject, does anyone have a spare 202 dampener? I am assembling a Jet motor, and need one, plus a set of valve keepers. Thanks,Geoff0
Geoff - you're probably better off starting your own thread on this. It would get a lot more views, and you're more likely to get the parts more quickly...Geoff
The one still attached to my parts Pacemaker's engine has a broken flange.
If it'll work for you, you can have it and shipping should be pretty reasonable.
Uncle Josh: Thank You for the offer. Chris is very near by.
Chris:... is it still on the engine? in other words should I bring a puller?
Yup - still on the engine.0
Chris, Sent ya an email.0
Problem solved by a generous Member! Thanks Chris.0
No problem.
I'm glad it's going to a good home.
- 994 Street Rods
- 175 The Flathead Forum
- 602 Vehicles
