Needed: A Broken Harmonic balancer
SuperDave
edited January 2015 in HUDSON
I am looking for a stepdown 6 balancer that has a broken flange. I Intend to modify it, and I don't want to destroy a good original part. Should fit into a flat rate box for shipping.
  • How about someone breaking one? LOL!
    Shameless bump to the top
  • Dave , I've get them but none are broken.
  • Dave,
    I have a few broken ones.......no, I didn't break them. If I told you the story, I'd get so pissed that I wouldn't be able to finish this post. I'd like to keep the hub and rubber discs if you can still use your originals.
    Frank
  • Frank,
     I'll need the whole thing..What I want to do, is grind the outer flange off and bolt on Cheby a double sheave to make a dual belt pulley.  I've done it twice but I had two busted ones to use. I just hate to destroy a good usable original part.
  • I have one that I just took off a 262 that was worn and locked up so bad it wasn't worth trying to take more of it apart.  You can have that one for the shipping.
    hetcramerlp@roadrunner.com   and do the delete
  • Whilst on the subject, does anyone have a spare 202 dampener?  I am assembling a Jet motor, and need one, plus a set of valve keepers.  Thanks,
    Geoff
    Geoff
    Geoff - you're probably better off starting your own thread on this.  It would get a lot more views, and you're more likely to get the parts more quickly...
  • The one still attached to my parts Pacemaker's engine has a broken flange.
    If it'll work for you, you can have it and shipping should be pretty reasonable.
  • Uncle Josh: Thank You for the offer. Chris is very near by.
    Chris:... is it still on the engine? in other words should I bring a puller?
  • Yup - still on the engine.
  • Chris, Sent ya an email.
  • Problem solved by a generous Member!   Thanks Chris.
  • No problem.
    I'm glad it's going to a good home.
