Brake Drums, 53 Hudson Hornet
As far as I know, they are integral, and removed together. Are you having a problem? If so, are you using the correct brake drum puller?
The drums are solid riveted to the hub and the hub is a taper fit onto the axle, it can be very tight. You need a good quality puller like the one in the photo.The poor man's method of hub loosening, assuming the car is still mobile, is to slacken the axle nut by 2 turns, put the split pin back in and drive around the block a couple of times.0
All, thanks for the information I just ordered a heavy duty hub/drum puller.
John
You really won't regret the purchase. Money well spent and it's the right tool for the job. Always a plus.
John0 -
....and if other old-car guys in your neighborhood find out you have it, you'll be amazed at how many new friends you have, LOL!
You might loosen the nut and spray some penetrating oil on the axle in the hub the day before you want to remove the drums.
I spent a day pounding on the pullers dog bone to remove right rear without penetrating oil. That evening I sprayed penetrating oil on both axles. Next morning the right hub popped loose easily with a few licks with one pound hammer and the left side came off easily with a few hits. .They can be very stubborn to get off. Don't forget to leave the nut on the axle so the hub/drum doesn't come flying off into private area when it lets go.
Lee O'Dell
- 994 Street Rods
- 175 The Flathead Forum
- 602 Vehicles
