1955 Hudson 308 Engine for sale
Engine Mileage
Gas mileage
Doe it use oil
When was engine pulled
Two barrel or Twin H
Does the main seal leak
Did it have automatic or stick.
Was it the engine you planned to rebuild
Did it run good or just ran.
Where are you located
Price for engine
Lee O'Dell0 -
Afternoon Lee,
The engine has a little over 50,000 on it, I do not know if got good mileage as I didn't drive it more than a mile away from home. I don't think it used oil, it didn't smoke at all. It had a couple leaks around the distributor and yes the rear main was weaping a little. It was out of a stick shift car with 3 on the tree (Borg Warner T-86) I have that transmission as well.
It has the original 2barrel carb that came on it (fresh rebuilt). The plan was to rebuild the engine for my car, however I am not going to be able to rebuild this car due to the amount of cost to get it complete.
I have a new exhaust manifold for the engine and all of its parts. I am located in East Bethel, MN. I was look between $550 and $600.
Drew
Hello Drew
Thank you for the information. Unfortunately MN is to far away from Ca. The rebuilt two barrel carb was a plus for me. The gas mileage on my last 308 with two barrel carb was 20 MPG.
Advertise your engine in the Hudson Club magazine - White Triangle News. That would give you a lot more prospects than on the Hudson forum. Good luck.
Lee O'Dell0 -
The engine is out of the car and ready to be crated. Fastenal? I attached a pic. The transmission and bell housing are currently removed from the engine.0
Is the new ex manifold separate or was it already installed?
I would be interested in the manifold and may be interested in the whole motor if there is a Fastenal near you.
Fastenal offers to ship large parts on pallets for a very reasonable rate between their stores.
Here's some stores near you. locations link
1321 Andover Blvd NE, Suite 110Ham Lake, MN USA 553041467 Lake Street South Suite 100Forest Lake, MN USA 550256937 Hwy 10 Suite 180Ramsey, MN USA 553030 -
Is the exhaust manifold a 1955 ? I think the outlet angle is different then the stepdown
manifolds.
The reason for the manifold is because the original one on the engine is cracked on cylinder 6. There is a Fastenal store nearby and I didn't know that they shipped. my email address is HETchoisserd@gmail.com (drop the HET). Send me an email if you would like to purchase the engine. I have it on a pallet ready to go.0
Sold! Thank you guys for the help!0
- 115 Hudson 1916 - 1929
