'27 Hudson window regulator
J Lombard
Hello All:
I need help finding the drivers side rear door window regulator for a '27 4dr Hudson super six.
thanks
J Lombard
thanks
J Lombard
You might try contacting Carl Weber in Massachusetts. Contact info is in the National roster.
He buys and sells a lot of "early" Hudson stuff.
thanks Jon0
Geoff Clark in New Zealand may also be a good soiurce.
Do you mean the handle or the whole mechanism?0
Geoff:
Sorry for delay. I need the whole mechanism.
I have these two window regulators that I believe are for 1926 Essex. Are they suitable? They have four points for the securing screws.0
Alistair:
Thank you for your response. No I'm afraid your regulators won't work. The one I need has three mounting points... two up top, one down low & the crank centered just below the two up top.
thanks again
J
J, is your car a standard Hudson body, or a custom? They used different regulators. Do your handles fit on with ap in through the boss, or a screw through the centre?Geoff0
When I get home I will look for one with three points - my '28 Essex uses this style so will see how many spares there are. THey still may not be suitable but let's see.0
Sorry for the delay. I have attached a photo of what I have spare. Let me know if these will help you out.
There is a 1927 Hudson that is being parted out, listed in the California Inland Chapter newsletter.
It was an aluminum bodied four door.
Ernie:
Thanks for your answer. However I think I found one just 400 miles down the road from here.
thanks again
J
- 590 "How To" - Skills, mechanical and other wise
