OD relay wiring when changing to Alternator
I'm putting a new 6 volt positive gd 60amp one wire alternator on a 51 Pacemaker. How is the OD relay wired now that the external voltage regulator is no longer used?
  • Number three to switched power , number 1 to battery power.
    The armature terminal doesn't get power until the generator starts charging.
    Wait for verification , working with old theory here
  • I hereby verify.  Just move the wire that was on the A terminal to the accessory terminal on the ignition switch, or somewhere else convenient that's controlled by the ignition's accessory terminal.
  • Thanks for the correction, Ken.  I should've said to connect it to the ignition switch terminal that's not going to the coil!
  • Thanks guys!
    Now to finish building and installing new wiring harness!
