Front and rear shocks for 1951 Pacemaker
This is what I have listedShocks Gas Gabriel 82028 Front Stepdown Shocks Gas Gabriel 81147 Rear Stepdown NAPA Advance PA15740132 Monroe 31176 34741 NAPA 94080 Advance PA15740070 Monroe 31094repl 34756 Shocks Reg Gabriel 82026 Front, 7 3/4 - 12 Stepdown Shocks Reg Gabriel 82154 Rear 13 3/16-21 15/16 Stepdown Monroe 20751 Monroe
20751
Sensatrac
5751 ST available at Summitt Racing and elsewhereDave0 -
I am assuming 51 pacemaker and 53 hornet have same front shock?!!!0
Monroe 37029ST for rear
Monroe 5751ST for front
Older info I found, had a set of both setting on the shelf. Mounted them on the 51 Pacemaker.
I have Monroe Max-Air shocks on the rear of my 1953 Hornet; the number is MA727.
The tech number at Monroe (Tenneco Auto) if you want to check your application is 734-384-7809.
These are PUMP-UP SHOCKS with an air valve behind bumper {or you could connect compressor if you wanted to.}
Here is photo of one.
The one with the air shocks in the rear:
I refer to my car on Gallery as: 'My Embellished Hudson'.
- 104 Essex Super 6
