37 hudson hood trim
nono1937
I need a hood trim molding if anyone knows where to get one or repair mine please let me know. I have pix. Of my broken one. Thanx....
Is that the Center hood Hinge or a side trim pc?
The center hood trim molding that holds both sides of the hood0
The Mack Truck hinge that was traditionally recommended for use in the '37 Hudson or Terraplane, was part #40 M12 P23100.
While you're at the parts department, ask to see a # 4QM12P5 from the "B" model Mack..
One other possibility I've heard: the center hinge for an MGTD, TC or TF. The part number 453-050 keeps cropping up, for this chrome plated brass strip. If you have a British car repair shop nearby, you could drive over with your broken piece and check the MG's out!
Here's a British company selling a similar hinge: http://www.vintagecarparts.co.uk/categories/vintage-car-parts-coachfittings-and-body-parts-bonnet-hinge . It's available in two different lengths. I don't see a make or model application for this hinge.
Early last year a series of similar hinges were sold on Ebay. Here is a link to the old auction (now ended): http://www.ebay.com/itm/1920s-1930s-CHEVROLET-HUDSON-REO-DODGE-40-REPLACEMENT-STAINLESS-HOOD-HI-/261365771248?pt=Vintage_Car_Truck_Parts_Accessories&hash=item3cda9d2bf0&vxp=mtr You could go to the auction and see if you can contact the seller to find out if he has more. Here is the actual hinge cross section:
(I think this is the same one that Ken U. just posted, above.
Not sure if any of these will work, but they're worth checking out.
Thank you Ken and Jon for the info....0
