Insulation
1954Hudson
What to use for insulation to control noise and heat in a Hudson pick-up ? Thanks
Think most people go with a product like dynamat xtreme or some similar...Hope it helps...Ray0
http://www.lobucrod.com/
Ive used his product on a couple of cars. If your a HAMB member, you get a 10% discount.
home depot/ lowes etc has an alternative which is in the roofing section it is a peel and stick product that is approx. $16 for 12.5 sq ft it is 6 inches wide and 25 ft long I used 4 rolls approx. 50 sq ft and spent $64 compare to dynamat etc sq footage and you will spend over $200 also contrary to others opinions this has no discernible odor but the choice is yours0
me 2
superDave-That's the stuff I always use. Only thing is, the surface you are sticking it to, has to be very clean (smoother the better). I also tend to use metal tape between joints. The stuff is thin, so you can also overlap it 1/2" to 3/4" or so. Price is Right!0
Thanks for info on roofing peel and stick product.
My experience with dynamat in my 64 El Camino was not pleasant the floor felt hotter with it. It absorbed exhaust pipes heat radiating through the floor and was like putting your shoe on hot tar paper. The noise and heat reduction was not close to what I was lead to expect..
Lee O'Dell
Unless, they have changed their product, it was my understanding that one was a noise reduction and one was a heat barrier and the two individual products did not do more than the single-duty they were designed to do. I used both on my last hot rod, which was a tiny '32 Ford. Cost was prohibitive. Can't imagine what it would take to do a closed-car Hudson.
Lee O'Dell0 -
Nice stuff Russell! I will look for it... Good for seams in sheet metal too I bet!0
I used both on the El Camino. Still have a lot left I got at the same time for the 34 Chevy hot rod before selling the it. Still have it. Will not be using it in the 47 PU.
Did what you suggested, dramatically reduce heat and noise? Would love to have a quiet 47 PU to hear radio and carry on conversation driving down the highway keeping up with traffic.
Lee O'Dell
Look at Eastwood, they have a Thermo-coustic product that is cheaper and goes farther then Dynamat. They also have a video on the website about it.0
I used the Dynamat alternative from the box stores in our model A roadster to quiet the drumming noise coming from the large metal panels. it worked pretty well.
On our metropolitan convertible, I used it on the floor pans to reduce noise and heat.
It helped a little, but after I added a layer of felt, and then placed a heavy rubber floor mat on top of them (just in the foot well area) the noise level was reduced to a point that you are no longer overwhelmed by road noise.
The Met is mere inches from the roadway...and gravel roads were especially obnoxious.
Rob
- 120 Hudson 1916 - 1929
- 612 Vehicles
