Ed Mueller's alternator bracket
Kerry, do you have stand alone pictures of the two pieces? email pls0
Looks good, Kerry!0
Good sturdy alternator bracket. Thanks for showing the pictures. Glade you figured it out. For those who do not know, Ed also makes A/C brackets and installs A/C systems in Hudsons.
Lee O'Dell0 -
I have a question a little off the subject can you use a generate with A/C or do you have to use a alternator0
Charles, I don't see why not, it's more about voltage I think and if the generator can produce enough to keep the extra load to the battery charged. The first AC units were generator driven. Finding a good 6v ac unit may be an issue.
The advantage of the alternator is that it charges at very low rpm where as the generator needs to be turning 1200 + if I remember right.
Ken, I don't have a belt on yet and it adjusted, but I'll check, I don't think it is going to be an issue.
When using a single belt for everything, the wrap {degrees} on sheaves of alt. and A/C is smaller than basically recommended by almost any authority. Result is that belt tension must be extremely high to prevent slip.
Best to use 2 belts with a 2 belt crank pulley; can be set up with either a 2 belt water pump pulley also or w/o a 2 belt water pump pulley to have at least a 90 degree wrap.Note this is BEST and not necessarily practical sometimes, nor are required parts always available when you need them. Just 2 weeks ago I looked at an identical A/C installation under the alt. that ran from a 2 belt crank sheave and everything was perfect; don't remember if the alt. or A/C just ran off the crank only. Naturally, a forward offset is required by one or the other.
I am running A/C with 2 belts but my A/C is mounted on the right side ( I also have a power steering pump mounted above the alternator).
my 2 pennies & FYI~~~
RichardD, I sure would like to see some pixs of your A/C, Alternator and Power Steering pump set-up. Thanks0
Wish someone would make SERPENTINE SETUP..0
You can get by with a little less with the wider, 3/4" belt than standard practices have dictated over the years. Typically, about 1/3 pulley coverage is accepted practice with the smaller belts and around 20-25% with the wider belts, is what I have come to find.0
- 103 Hudson 1916 - 1929
- 90 Essex Super 6
- 28.5K HUDSON
- 172 The Flathead Forum
- 599 Vehicles
