46 Front Shock No.
Uncle Josh
Anybody got a good number?
According to the mechanical specifications manual in the library (found here http://www.hetclub.org/index.php?option=com_booklibrary&task=view_bl&tab=getmybooksTab&is_show_data=1&id=742&catid=112&Itemid=1096) these are the numbers and makes from back then:
1946 Models
SERIES BODY TYPE FRONT REAR MFR. SCALE
51 Exc. 3–P. Coupes, Club Coupe 16754 165755 Monroe Light
51 3–P. Coupe, Club Coupe 165750 165751 Monroe Light
52, 53, 54 Exc. 3–P. Coupe, Club Coupe 165875 165871 Delco Light
52, 53, 54 3–P. Coupe, Club Coupe 165873 165871 Delco Light
58 All 165874 Delco Heavy
Note: Part number 165874 shock absorber assembly front, used with optional heavy scale front and rear springs. Part number165871 shock absorber rear, used with optional heavy scale front and rear springs.0 -
napa rr-94008monroe 310000
thanks boys but Paul, your numbers are no longer good and Charles, yours are both for rear as they have double loop ends0
Try 5751 Monroe0
I did think it'd be optimistic that they were
Dr. Doug has front shocks here as well : http://www.wrphet.com/driveline---suspension.html
Monroe 5751, 31176, Gabriel 820280
Delco #550-1370
Thanks0
Let us know which ones you ended up installing0
Park, I think either Monroe would fit. Double end threads and both carried by Rockauto. I like the 31176 better at 11.35 vs the other at 29 and change. Gonna check the car to see if they'll go.0
- 104 Essex Super 6
