Hydramatic Seal Replacement
I need to replace the transmission seal on my dual-range Hydramatic (1953 Hornet). I have a seal that I can use but it will not accommodate the seal dust cover. The original seal has an overall thickness of approximately 7/8". The replacement seal I bought is only about 7/16" thick and goes completely inside the tail shaft housing. The dust cover fits over the original seal. Does anyone have a part number for the original type seal and where it may be purchased from?
Thanks!
Joe
Hi Joe
U can easily remove the dust cover with bi-scrips and a hammer. To replace your seal. So tranny did not have them is really isn't needed0 -
Joe, I have an extra one on my shelf. National 7037S. Give me an email at rsotardi@yahoo.com.0
I have ordered a couple sizes from Dave Edwards of Autotran. He had a 1" that is for a 51 Olds and also a 3/4".I'll see if they will be usable. He said both of the seals were made by Chicago Rawhide. Thanks to Russ and Ron for the information.0
Is the number national seal no. 7037S for the tail shaft for 54 hydra matic. Ray0
- 96 Essex Super 6
