GM H.E.I. Electronic Distributor Conversion by Ron Fellows
Ol racer
FOR SALE
GM H.E.I. 12V Electronic Distributot converted for Hudson Hornet 6
Includes MSD 6AL Ignition Box, GM H.E.I.Distributor modified to fit Hudson, Distributor Cap, 8mm Super Stock Wires, and Mallory 12V Coil.
Unit only had 2 weekends of use at Drag Strip.
$375 O.B.O.
Contact Ron Fellows (clutchman) @ 915 877 9025 hudnutz39@spcglobal.net
$375 O.B.O.
What does do about a vacuum advance with this type of unit?
Allan
Ron Fellows said most modern distributors vacume Adv needs turned way down or off. Set 8 @ Idle.
If ya think about it. The function of the vacuum advance is to retard the timing during acceleration. If the centrifugal advance is properly designed. The vacuum is irrelevant. Uh... I think.0
That's right on the money, Dave. Here's a secret: I don't even run a vacuum advance due to the different tuning requirements that modern day gas has brought upon us.0
Will this type of setup fit a '54 232 Hudson?
Rick,
Yes, This Set Up will fit any 232, 262, & 308 Hudson Motor.
- 105 Hudson 1916 - 1929
- 173 The Flathead Forum
- 599 Vehicles
