1929/ 30 Essex drums
Generally thee is little that will interchange between 1929 and '30, but I think you may get away with the drums. Measure first, both diameter, width, and bolt spacing. There are issues with removing drums. The bolts were cut off with mechanical shears, which had the effect of roughing over the ends of the threads, and it is likely that the bolts and nuts may strip when being undone if you do not carefully grind around the ends of the bolt where it protrudes slightly above the nuts on the inner end.0
