Part number identification
54SuperWasp
Hi guys, a friend of mine would like to know on what car that part would go. Number on the tag reads: 7 4184 8E
Any input will help. Thanks, Michel
Looks like a generator tag0
Starter Motor?
It's a starter motor, but I can't find any reference to that number in Motors Manual listings for Hudson 1935-49, nor 1950-54 manuals.0
Will try to get more infos from the guy. Thanks! Michel
looks like MZ 4184 to me. Probably 55-57 Wasp? Maybe a letter is obscured.0
I found a reference to it being a starter motor fitted to a 1951 Commodore using MZ4184 plugged into google0
Ken is right...Just for heck of it.. I used a Jet starter on a Hornet I converted to 12 volts.(HydraMatic) Bolted right on . It was physically smaller but worked great and as far as I know, it's still going 5 years later.0
No, it is a MZ 4164, it interchanges with MZ 4167, used on the 232 motors, as it is a lower torque starter of 4.4 ft/lbs torgue versus 6 ft/lbs for the 262/308 starters. May work OK on the bigger motors if used on a 12V converted car. Also works with 202 Jet from what I can see.....
Easy to see it's a 6 , after you pointed it out . Probably fit's the 55 wasp also? Not sure where I got that info.
You guys are great! This man should be very satisfied with all your inputs! Thanks again! Michel
- 994 Street Rods
- 174 The Flathead Forum
- 602 Vehicles
