Total 308 overhaul. What would you do?
2»
  • Kerry see
  • Couldn't post the link!!. look on YouTube for "
  • Grumble!!
    try looking on YouTube for "" Lester J Harris gives David 'Dutch' Schulz a tour of his Antique Auto parts Warehouse""
    I found him great to deal with.
  • How did you do that Russell?
  • Copy and paste.   .  . . that's all I did.
     . . . in oher words, I don't know.
  • Man!  What a treasure!   Both parts and the man...k
  • Maas double roller timing chain, big valves and valve guides on the way! Thanks Randy and Steve!
    Meanwhile back at the shop after a hot tank bath the block shows a crack in the #3 cylinder between the exhaust valve and the cylinder. It is an old one and was sorta repaired by being "pinned."
    The plan is to sleeve the #3 cyl to stop the crack between the sleeve and the new exhaust seat. Possibly sleeve #6 as well, due to deep rust grooves in the wall. Going to press in the new valve guides, then bore cyls to size.
    Mike
  • Mike-If we can be of any further assistance, please let us know.
  • Steve, I am sure I will be in touch after the holidays with a fresh list of goodies.
    Mike
  • Simple, I would call Randy Maas and have him rebuild it for me.  A lot less headache.  He can build the engine to the way you want to drive, be it on a Sunday afternoon or a Friday night drag strip....
  • GREAT info in these posts!!!!  Lots of years of experience packed into all these comments!!!  I am also looking into rebuilding another 308 to put into my 52 Hornet with 3 speed and od. Found a 56 engine which has the advantage of hydraulic lifters (maybe), better cam and porting. But it sounds like the crank is a problem as it is shorter. Would using a Stepdown era crank in that block be the easiest solution, or is there an adapter that works well on a clutch car?  I have a 52 crank that is in good shape already.
  • Ken, where would a person source a 1/2" spacer? I read somewhere that the 55-56 cranks were improved over the earlier cranks. I have a stepdown crank- good to hear that it is a drop-in replacement to make it work in an earlier car!!!
  • I have the spacers also for $80
    Don
  • Has anyone ever used one of the spacers on a 3 speed? I have only ever heard of them being used on Hydramatics.
  • I just pulled the head and pan from a 308 thought to be a 1956. Came out of a 1951 Hornet.  It may be a "crate" engine that was sold to install in earlier Hudsons. It has the larger crank flange, 1/2" head bolts, and 2 holes for a dipstick. The front hole was plugged with a whlttled down piece of wood to plug it!!! The cast iron head says "High Compression Premium Fuel only".  It had no serial number stamped in it. I am wondering if there was any other ID marks that would identify it for sure. I have the flywheel that may have been available to install it in the manual trans stepdowns. It has the larger bolt pattern to fit the crank, 1/2" bolts threaded into the crank, and the 2 drain plugs for the cork clutch. Looks to have about 1/2" offset to the rear. Is that the flywheel that I need for a 1952 with overdrive??  I'm sure hoping so!!!!
  • What are people's thoughts on the 55-56 hydraulic lifters? Are they reliable or is it better to switch back to the adjustable ones? I am running Clifford headers on my 1952 Hornet, so it would be an advantage to not have to adjust them.
