WANTED: 1941-47 8-cylinder radiator
Jon B
Administrator
A friend needs a '41 to '47 8-cylinder radiator with all the mounting hardware. I think he'd gladly buy a used one so long as it was in good shape, or only had some minor damage that was easily fixable.
Or, if you have a damaged radiator, and he could at least salvage the radiator mounts and shroud, that would be great as well. The 8-cylinder hardware is evidently different from the 6-cylinder.
Please PM me or e-mail me at XXXdetailed@verizon.net (drop the X's before sending). The friend is located in Northern Virginia, by the way!
I'm bumping this to the top!
The only difference is the number of cores, ie thickness. 2 for the 6 and 3 for the 8. I just had a 2 core re-cored with a modern core which is more efficient and it works fine in my 47 pickup with a 254. Can't put a 3 core in the 2 core radiator because the upper and lower tanks are too small.0
- 97 Essex Super 6
