Heat Gauge
WaynePorter
Hi all;
I have a 28 Hudson Landau with a twisted off heat gauge tube. Does anyone know where the gauge might be repaired?
Thanks for any info;
Wayne
If you can wait until after my return home on Sept 20, I'll send you an article on repairing/replacing the bulb assuming that's your problem.The article maybe too big to paste on here so PM me your direct email address.
David Young (28 Essex RS Coupe)
Thanks Dave
Delay is not a problem as I'm going on vacation as well. The tube twisted off at the two piece fitting going into the block. I was able to salvage the fitting that goes into the block, but the one that goes into that fitting was destroyed.0 -
Here is an article on repairing temp gauges and a Youtube video. The gauge repair starts about 2:35. Also there are companies that will repair your gauge.0
Wayne
Mars55 has pointed you to the same article I remembered. http://www.ply33.com/Repair/tempgauge
Good luck & be careful of open flames whlist doing the repair.
Dave Young
Thank you guys; I will check out that video.Wayne0
https://www.youtube.com/watch?v=Z3GPn4rN9Nw
