Battery quality
Lately I am having huge issues with 6 volt batteries purchased locally, not holding a charge or failing on the car, in one case this cased my recently rebuilt generator to overcharge which destroyed the new armature.
 The discussions I have had with the generator rebuild guys point to the quality of the batteries as the source of blame.
Interstate and AC delco are the two I have bought, apparently these are now manufactured off shore?
Are there any manufacturers making good quality batteries any more?
  • Dave,
    I'd recommend switching to the Optima. They're several things:
    -Expensive
    -Don't look "correct".
    -Powerful
    -Clean (no leakage so no corrosion issues)
    -Mount in any position, although inverted isn't recommended.
    -Higher voltage (by about .5 V in the 6V version)
    -Last about twice as long as a lead/acid battery
     I have one in each of our three Hudsons. Just Frank's opinion.
    Frank
  • For the purist , you can " disguise" the optima.
    Someone makes cases to hide them in.
    Napa still has decent batteries. They sell a lot to the tractor guys.
    I've always used Napa , and get about 5 years out of them.
    They have some of the highest cold cranking amps of all.
  • Lostmind,
    Do you know the make of the Napa batteries ?, we don't have a Napa in the little town I live in up here in Canada but we can get most stuff if I know which one to ask for
    Dave
  • Optimas are fine batteries, no doubt about it.  You should have zero problems with them.
    If you want sometime a bit cheaper, in a traditional lead battery, I suggest you look at DEKA.  It is made in Pennsylvania.  I have used them for some years. They have a very good CCA (cold cranking amps) rating, about 780 -- almost that of Optima.  However, they will not last anywhere near as long.  You might get 4-5 years out of one, whereas the Optimas can last much longer.  I bought an optima last year at the Batteries Plus chain of stores and I think it cost about $90.  This is for a 6-volt Group 2 battery, which most of our Hudsons use.
  • lostmind
    edited August 2015
    Lostmind,
    Dave
    East Penn Manufacturing Co.
    I tried to post a link twice , won't stick
  • Here's the list of DEKA batteries -- the group 2 is up near the top.  http://www.eastpennmanufacturing.com/wp-content/uploads/Deka-Commercial-Batteries-Flyer-0010.pdf
    For some bizarre reason they list the CCA as 675, which is not a particularly powerful incentive to buy it.  That's what it said in last year's list, too.
    When I got the battery home, it said "780 CCA" on it.
    Go figure.
  • I've had Optima batteries for over 10 years in two 12v cars and they're still going strong. Two months ago I installed an Optima 6v in my '29 Hudson. A friend is using the same in his '29 Pierce-Arrow and he's delighted!
  • The one on the right is now 6 yrs old. One on the left is probably 3.  800 Cranking Amps per battery, but hooked up in series still only 800CCA.  Right Frank?
  • Welllll. Unless my eyes are playing tricks on me (again) that appears to be a parallel connection of two six volt Optimas. Please verify. In that configuration, the quick math would put it still at 6V but double the current producing capability @ 1600.  Logic would dictate that a series connection would produce 12V at the same current rating (800) as a single 6V.
    F
