Hudson trim polishing guy
george iverson of iverson automotive in minnetonka, MN. is the best trim and potmetal chroming guy in yhe country if you can't find anyone to do your trim.
http://www.iversonautomotive.com/
Kerry - fellows name R.P Moore
I believe he returned to NW US0 -
Bellbigdawg, I just sent him a batch, we'll see how it goes!
Oldfarmer almost had it right.Rick Monroemoved back to OregonWorked with Jim Harmon for many, many years.210-584-5856HETmongoose8220@att.net (drop the HET)Best stainless man I ever saw.0
Yep, It was Rick Monroe. He used to live here in Schertz, Texas. I found an old note attached to his business card that I had written a long time ago that simply said Jim Harmon back to Oregon.Oh and Hi there RL Chilton!Peace,Chaz0
I have contacted Rick Monroe. He lives in Kuna Idaho & I will be meeting him Friday to deliver my '53 Hornet stainless. I will let you know how it turns out. Talking with him he seems like very knowledgeable about Hudson stainless. Russ's contact for him is good.regardsJ Lombard0
Dose he cut down stainless have some from same year wrong model just to long just wondering0
Charles-Yes, Rick can do that. Just talk to him about it.0
go to top0
If it has a twist in it, if it has holes in it, if its bent 45 degrees, if its been hit by a rock, you will be amazed when you get it back. How in the ____does he do that. Rick is a Master. Always comes back just like it came from the factory.0
Hopefully, we can talk John Fromm into doing a video on polishing stainless steel, as he knows how to do it.:)0
Might want look at polishing SS on the car. Part 1 of 4 videos.
Use a 10,000+ die grinder not a drill. Also use blue 2" tape but put gorilla tape on top of it (do not stick directly to paint). Progress with polishes; Ace Hdwrs. has most of this--saves ordering from Eastwood. Have done about 1/2 of mine--waiting on colder weather when outside work stops.
>>>>> https://www.youtube.com/watch?v=wPg9mNr5fhQ0
