center steering pin/bushing
MissScarlett
My 51 Pacemaker center steering needs rebuild/replace. Tire tearing toe in is not present. What are sources/suggestions for bearing, parts, bushings? I was told specifically of "oil lite" bronze bushings.
Many times you only need the bushings.
http://openforum.hetclub.org/discussion/166936/bushing-for-center-point-stg-1948-54#latest
If you have to have a new center pin, it will need to be drilled for the tapered lock pin.
I take mine to a local machine shop when I need this done.
Also you may only need the pin properly shimmed to take care of the play.
New center pin & bushing installed, unable to find means to adjust driver's side camber. What am I missing?0
Here is a link to a picture of the camber adjustment;
It is easy to see if you remove the wheel.
Loosen the lock nut, and turn the eccentric bushing to adjust camber.
Rob
