Brakes locked
I have had the 40 on jack stands while I worked on several things; not the brakes.
I took it off stands this morning to go for test drive and it feels like the emergency brake is still engaged. I put it in reverse to back out of garage and it felt very tight. When I depress the clutch it did not free wheel or roll at all. I probably did not move more than about four (4) feet. I then tried going forward and I got the same results. I reset the emergency brake and then released it and tried again. It still felt the same and the car would not roll.
I don't know how to check the emergency brake to see if it is released. I stepped on the brake pedal and it is hard, but I don't see how the brakes could have locked up while the car was on stands.
Any guidance is appreciated.
By-the-way, one of the things i did was remove the oil pan, clean the sump, repair the oil sump screen where it had torn loose. I stared the engine and let it warm up. I then checked the oil and it is so clean on the dipstick; makes me very happy to have gotten that taken care of.
Anyway, back to the brake problem, let me know what you think I should do.
Jack the vehicle up see if all the wheels are lockd up if the front turns freely then its the rear jack up the rear put un jack stands pull the drums have someone put the ebrake on see if they move if they don't your cable might have rust on them in the caseing they would needed to be lubed maybe wd40
