Differential ratio
Ray, Although Hudson did not use any ratio under 3:07, you can still get gears for this rear end. What you have to do is check with a Jeep source for the lower ratios. The rear end used by Hudson in the 54 model year was a Dana 44 for which parts can still be obtained at different ratios which Hudson did not offer. Check with Jeep on what you can get ratio wise.0
I had a look at this once, there were ratios faster then 3.07 available for the Dana 44 but not by much, 2.8 maybe. Going the other way, there were plenty of ratios for the rock crawling crowd, 5.5 maybe even 6.0. Ford, Chrysler and AMC all used the Dana 44 from time to time.You may need a different crown wheel carrier for your faster ratio diff, the carriers are different between Hudson's 4.55/4.11 and 3.07 ratios, something to be aware of.0
Thanks for the help0
Yo Ray!! You need a faster Dana 44 so you can drive down to Texas, this coming January right?0
YO Gramps. Do you have one .. Ray0
Ray,
Walt says he installed a 2.73 in his. 4OO RPM reduction over the 3.07
If you find one/go through with the swap I'm interested. I want to put one in mine as well.
Rob
Hi Walt Where did you find the 2.73 gears for your Hudson or did you replace a complete diff. What kind of a vehicle . Ray0
2.73 diff gears will give you an 11% reduction in revs over 3.07 gears.A stepdown with 3.07 gears is typically doing around 2200 rpm at 60mph, 2.73s will drop that to 1950 rpm.0
Where do I find a set of 2.73 ratio gears. Thanks for all the reply. Ray0
Found this on the Dana 44 crown wheel carriers, it looks like they only use 2 carriers, one for 3.92 and up, another for 3.73 and down.0
I guess you could flip the axle over! LOL0
Check with the Studebaker folks, Studies used the Dana 44 also and the members ther have come up stuff for that setup ??0
The Stude axles are a different size, they have flanged axle conversion available.
I recently installed a twin traction with 3:55 ring and pinion into a Hudson dana 44 rear end.
Remember, the hudson axles are 19 spline so that has to be matched with 19 spline spider gears. Several makes used the Dana 44 rear end.0 -
I bought a 2.73 gear set several years ago and installed it. I love it. It quiets the Hornet down on highways and changes the hydro shift points very nicely. I was able to find them new through a warehouse in Mexico. This was about 10 years ago and they were scarce back then. I hope you find a set as they really improve the comfort on long trips with no real degradation of acceleration
Lew0
- 104 Essex Super 6
