OVERDRIVE, HEADLIGHT RELAYS FOR SALE
I have new 6 volt,40 amp cube style relays for overdrive. comes with socket, lead wires, 30 amp inline fuse and instructions. $45.00. New cube style 6 volt 30 amp relays for headlights with socket, lead wires, 14 amp inline fuse and instructions. Recommended for better lights and to relieve load off Headlight switch
$65.00 for the pair (one for low beam and one for high beam) Signal light switch for 1954 Hudson (also 53-54 Jets) good condition, tested and works.$35.00.
all parts plus postage. Contact JIm Spencer at HETjimreen@frontiernet.net (drop HET) or call five85 654 ninety four fifty.
I verified that the signal light switch I listed for 1954 Hudson does also fit 1953 and 54 Jets.0
Jim, I think you mean Sunday the 11th! And, for those who don't know, the Hudson people stay at the Quality Inn outside Carlisle, just a stone's throw from the Rte. 81 "Middlesex" exit.
Incidentally, Jim, you might want to leave a note on the bulletin board of the Hudson booth in the Red Field, reminding people that you have these for sale and will be at Hershey and the Carlisle hotel.
Jon B, thanks for the correction on the date, must have been looking at Sept.. I do know where the Quality inn is and thanks for the suggestion putting a reminder at the Hudson booth.0
I sold a couple of the relays at Carlisle sunday AM and a few more were interested0
Jim
How much?
Lee O'Dell0 -
Lee, The overdrive relay is $45.00 and the Headlight Relay (pair) is $65.00. Both plus postage (about eight bucks priority mail) All relays have been tested. I have also changed wiring to 6 volt specs. I have had the overdrive relay on my 51 Pacemaker all summer and it has worked perfectly I wanted to check it out good before I offered them for sale. Thanks for your comment.0
Reposting updateJ Spencer said:I have new 6 volt,40 amp cube style relays for overdrive. comes with socket, lead wires, 30 amp inline fuse and instructions. $45.00. New cube style 6 volt 30 amp relays for headlights with socket, lead wires, 14 amp inline fuse and instructions. Recommended for better lights and to relieve load off Headlight switch$65.00 for the pair (one for low beam and one for high beam) Signal light switch for 1954 Hudson (also 53-54 Jets) good condition, tested and works.$35.00.all parts plus postage. Contact JIm Spencer at HETjimreen@frontiernet.net (drop HET) or call five85 654ninety four fifty.PLEASE NOTE Headlight switch has been sold 3/14/20130 -
J Spencer said:I have new 6 volt,40 amp cube style relays for overdrive. comes with socket, lead wires, 30 amp inline fuse and instructions. $45.00. New cube style 6 volt 30 amp relays for headlights with socket, lead wires, 14 amp inline fuse and instructions. Recommended for better lights and to relieve load off Headlight switch$65.00 for the pair (one for low beam and one for high beam) Signal light switch for 1954 Hudson (also 53-54 Jets) good condition, tested and works.$35.00.all parts plus postage. Contact JIm Spencer at HETjimreen@frontiernet.net (drop HET) or call five85 654 ninety four fifty.Updating post, all parts still for sale.
- 104 Essex Super 6
