Spark Plugs
pmlmbigpondcom
G'day All
As I have posted previously, I have an 8 cyl 1937 engine with an Edmunds head.
Does anyone have advice on the correct spark plugs for this head ?
Thanks
Phil
Thanks
Phil
Phil
If you want 18mm long reach (1") I can help from NZ
I can send you a spec sheet if wanted.
David Young
G'day Dave
Not sure what I need
I'll let you know if that turns out to be the spec
Thanks
Phil0 -
Your plugs are 14 mm, and a Champion J8 will work fine.Geoff0
Lawn mower spark plug0
Charles
Lawn Mower !!!
How degrading !!!
Phil ( smile )0 -
J8 is used in lawn mower check it out0
But.....it's also the same one spec'd for the '59 Cadillac Eldorado Special 390 engine. Nuthin' degrading about that!
F
Nope0
Much happier now
Phil0 -
You could always park the Railton on the lawn!0
- 184 The Flathead Forum
