Need front wheel bearing seal numbers 48/54
Kerry old thread with PNs
http://www.hetclub.org/forum/discussion/161651/stepdown-front-wheel-bearing-seal-p-n-s0 -
After reading all this and becoming totally confused, what is the CORRECT number for a 1953 Hornet front spindle seal ????
Surely someone has a correct number for this most common part; if not this one, others might be extremely obscure.
tks
R
RockAuto has~~
Ken, how about I take the old info and put it on an Excell spreadsheet , I can put a column in with numbers and another with up to date known good to purchase numbers? I did look at the old info to start with but could not find a cross over number for those older numbers. The only thing I could find was the 471831 number by application.
Sounds good Kerry0
- 96 Essex Super 6
