Hydro Crossmember & Sill plate
Ol racer
I am looking to buy a Hydromatic Crossmember and a pair of used 2 Door aluminum Sill Plates decent enough for a driver.
Thank You,
Chuck
Thank You,
Chuck
Chuck I've got a very decent hydramatic crossmember . What year 51-53 or a 54? Got both. 704 792 9110.0
Just curious Lance.. What is the difference for a 54?0
Dave, A 54, for some reason is a bit narrower on the 'ears' than the earlier years. Don't know why. I didn't notice this until I had to use one to accomodate a hydramatic on a 51 I was installing. I was going nuts trying to figure out why the tranny would not slip quietly onto the cross member. I later checked the parts book and sure enough there are two different part numbers for the 51-3 hydramatic and the 54 hydramatic. When I went upstairs and got another hydramatic crossmember it slipped right in . No problem. When I later did a side by side comparison you could see the 54 was a slight bit narrower on the 'ears' than the earlier ones. Weird.0
No Ken, This was a GM hydramatic. I know what you mean about the Borg cross member on a 54 but this was a GM hydramatic. There is a separate Hudson part number for in in 54 only.Check it out in the parts book.0
Chuck, Best time is late morning . L.0
Chuck, I have decent door sills for you
Dave,
Thats Great., Let me know what you want for them here or cv.cars@verizon,net
Thank You,
Chuck
Chuck, I sent you email0
- 120 Hudson 1916 - 1929
- 612 Vehicles
