1928 Essex prop shaft lube?
Hi again folks,
I'm not sure how to go about greasing the prop shaft UJ's. The shop manual shows a "casing plug" but no visible grease nipple anywhere in the diagram. Do I just remove the casing plug and use the grease gun to squirt grease into the casing, or is there some better method? As always, your help is much appreciated.
  • Remove the plug and fit a grease nipple.
  • You're the man Geoff! Thanks as always
  • The grease could blow out the seal, so do it slowly..
    In 1931 there was a hole in the cover on the opposite side for the plug, so you could see the grease come out and know it was properly lubed.
    I have debated drilling a hole but have not done it yet.
    Be sure to remove grease nipple and reinstall the plug.
    This per the 1931 service letter
    Hans
  • Thanks for your advice Hans, much appreciated.
  • There is no need to  replace the grease nipple, just leave it there.  I have had one in my Essex for 60 years!  And do not drill any holes.
    Geoff
  • OK Geoff, thanks.
