witch cam shaft
i have 2 new cam shaft one is a clifford lift 372 int 372 exh,  254 duration int - exh
iskenderian lift 437 int 437 exh, 262 duration int - exh the motor i am build is 1955 308 ,030 pistion 262 head ported a little more releaf maas timing chain twin H and header full flow oil filter.  i know the isky cam will idel a little rouf but wil it be streetable in town and highway has any one put this cam in a driver not a drag or race car looking for fun and driveabilty. Thanks
  • i for got im puting 7x large velves
  • I didn't know witches had cam shafts.  Another occult fact that is not well known.
  • For sale, one supercharged broom, hot cam, headers, streamlined handle,  super-slick bristles.   Apply Badjelly the Witch.
  • Actually the Isky race cam will work nicely with the auto trans.  The problem many run into is the carb factor.  Will not run correctly with your stock WA-1's unless modified to accept larger venturi's.  Will idle nicely around 700 rpm. Randy
