1931 essex brakes
There is no easy fix apart from painstakingly setting the anchor pins, eccentrics and star-wheel spreaders. You must use a feeler gauge through the inspection hole to get the correct clearance. Too much clearance at the bottom will give you the effect of no brakes forward. Basic settings are (in order). Actuator slightly behind centre, with a slight gap between it and the cam arm. Loosen anchor pin nuts, and eccentric backed right off. tighten starwheel as tight as you can, then tap anchor pins, repeat. Tighten anchor pin nuts, and back off starwheel until wheel turns free. Turn eccentric so shoe just drags and back off slightly and tighten. Turn star wheel until wheel just drags and back off slightly. Good luck,Geoff0
Welcome to the Hudson Open Forum, Mnchrist! Geoff is the MAN when it comes to vintage Essexes.
- 96 Essex Super 6
