OVERDRIVE, HEADLIGHT RELAYS FOR SALE
J Spencer
edited October 2015 in HUDSON
I have new 6 volt,40 amp cube style relays for overdrive. comes with socket, lead wires, 30 amp inline fuse and instructions. $45.00. New cube style 6 volt 30 amp relays for headlights with socket, lead wires, 14 amp inline fuse and instructions. Recommended for better lights and to relieve load off Headlight switch
$65.00 for the pair (one for low beam and one for high beam)  Signal light switch for 1954 Hudson (also 53-54 Jets) good condition, tested and works.$35.00.
all parts plus postage.  Contact JIm Spencer at HETjimreen@frontiernet.net (drop HET) or call five85 654 ninety four fifty.
  • I verified that the signal light switch I listed for 1954 Hudson does also fit 1953 and 54 Jets.
  • Jim, I think you mean Sunday the 11th!  And, for those who don't know, the Hudson people stay at the Quality Inn outside Carlisle, just a stone's throw from the Rte. 81 "Middlesex" exit.
    Incidentally, Jim, you might want to leave a note on the bulletin board of the Hudson booth in the Red Field, reminding people that you have these for sale and will be at Hershey and the Carlisle hotel.
  • Jon B, thanks for the correction on the date, must have been looking at Sept.. I do know where the  Quality inn is and thanks for the suggestion putting a reminder at the Hudson  booth.
  • I sold a couple of the relays at Carlisle sunday AM and a few more were interested
  • Jim
    How much?
    Lee O'Dell
  • J Spencer
    edited October 2015
    Lee,  The overdrive relay is $45.00 and the Headlight Relay (pair) is $65.00. Both plus postage (about eight bucks priority mail)  All relays have been tested. I have also changed wiring to 6 volt specs.  I have had the overdrive relay on my 51 Pacemaker all summer and it has worked perfectly  I wanted to check it out good before I offered them for sale. Thanks for your comment.
  • J Spencer
    edited March 2016
     ninety four fifty.
    Reposting update
    PLEASE NOTE Headlight switch has been sold 3/14/2013
    Updating post, all parts still for sale.
