Bearing Question
What does the BVV stand for on a 88107-bvv?  And is the same as a 88107 without the bvv?  Can't find any info on the web about it.  Btw its the center driveshaft support bearing.
Thanks,
Ray
  • Thanks Ken!
    Till next time!
  • Just updating this post for those folks that might order the wrong part like I did. I ordered the 88107 for my '50 commodore and it should have been 88506. :(
    '48-'52 All Exc Pacemaker and Wasp use #88506
    '50-'52 Pacemaker and Wasp use #88107
    '53-'54 All Exc Jet use #88107
    Hmmmm. The Jet doesn't have a center support bearing. Maybe the outfit that spec'd it didn't realize that detail.
    F
  • 50ClubCoupe
    edited May 2016
    it could be that the 'Exc Jet' is supposed to be interpreted as the Jet not requiring one but I agree, it makes it seem like the Jet requires a 'different' one rather than none at all. I had pulled the information from a different thread on the subject and just wanted to share in case someone, like me, came across this one and assumed the 88107 would fit all stepdowns.
  • Oooops! I just mis-interpreted what I saw. Brain fart.
    Frank
  • Are you kidding? It probably does but I don't remember.
    The obvious error in my screw-up is that "'Exc. '53, '54 Jet" is just about the most common phrase in our hobby.
    F
