Street rodding a 46 Hudson coupe
jr38special wrote:Would I need a front clip to put a 350 sbc in a 46 Hudson Super Six coupe or will the stock front end be allright?? I would like to have power steering as part of the package. Also how would the rear end be if I went with a BBC like a 454 instead?? Thanks JR
How much are you going to spend? Who is going to do the work? When do you expect it to be done (or how long can you go without driving it!)
If power steering is a necessity then you may well need to to a "front clip" or better called the cradle with the steering and wheel to wheel suspension. Fat Fab may make a kit..I know they have one for step-downs but thats a whole different beast as I assume the 46 has a full frame?
Generally the only thing you want to do with a full frame is make sure its not cracked or bent and if its not boxed - box it!
The rear axle also depends a lot on the useage - I'd say plan on 250 - 2500+ depending on your needs but the original one would work for a while if you kept your foot out it - I suppose...
For my 49 I kept the original front suspension (with a slight steering mod) - modified a crossmember and added a new rear x-member and stuffed a 454 and TH400 into my stepdown.
I'm keeping the manual steering because thats the way the car was built and I don't plan on parrallel parking it - EVER...
I haven't done all the legwork yet but I'm going with a modified rear axle for the 49 because of the space requirements and I'm most likely going to pick up a newer Ford 8.8 w/31 spline axels and Disc brakes and then have the housing shortened and new axels made. They're cheap (quoted 400.00 stud to stud w/disc brakes) - probably be into it about 1600-1800 for a bolt in setup.
Anway - There I've answered your questions with questions and dispensed some hard earned advice and went on and on about my car... but if you haven't yet...Check out the website - it might give you some ideas - even though yours is different in style and construction.0 -
Good luck and keep me posted.
Jerry (U.K.)0 -
Anyway, have fun and post some pics when you can. Lots of guys here to help ya.
Jay0 -
hi hudson dave here. i have done three of them now with p/s disc. brakes all with hudson front suspension . very inexpensive rear brakes off 91-98 ford c/v fit on the front with no problem .izzu steering fits and uses all o/e hudson linkage. i payed $75.00 for steering and $100.00 for every thing for the brakes including the hoses.for more info go to wwwfatwhitewalls.com and give me a call i would be happy to walk you throw it 61-63 big car ford 9' works perfect .all kinds of gears to pick from. i am using 3.0 in my 46 4 door and 3.25 in my 46 p/u. HudsonDave0
- 86 Hudson 1916 - 1929
- 11 Upcoming Events
- 74 Essex Super 6
- 28.4K HUDSON
- 990 Street Rods
- 72 Hudson 8
- 592 Vehicles
