254 - 8 harmonic balancer interchange?
47powerdome8
Will a harmonic balancer/crank pulley off of any Hudson sixes (212?) work on a 254 or does it have to be from an 8?
Again, thanks in advance!
You can use any dampener 1934 thru 1947, and probably up to 1952 8 cyl. They used the same for 6 or 8 cyl.Geoff0
The 166301 Vibration Dampener is specified for all '46 and '47.
It's also for all '38 to '42 but with an earlier p/n (155480), superseded by the above #.
F
If you look at the Hudson interchange manual, the part given for the '34-'36 dampener says to use the later '38-'42, which says to use the '46-'47. 8's continued up to 1952, and I am not aware of any differences in the dampener for those years. It may have been in the construction, but the nose on the crank is the same size.Geoff0
- 109 Hudson 1916 - 1929
- 176 The Flathead Forum
