54 power brake photos
Bob,Here you go, hope this helps. Let me know if you need additional photos.John Forkner0
Thanks John, that's just what I need. Can I ask for a dimension from the edge of the brace bracket to the centre of the first hole please?It looks like the 2 top holes are half on half off the the horizontal seam, so that determines the vertical position of the brake pedal quite neatly.0
Bob,It's 1 7/8" . You are correct in the location of the holes on the horizontal seam. Make sure to note the orientation of the brackets on the firewall. After you get the first hole drilled you could bolt the brackets to the power unit to get the other holes lined up and marked.0
Bob-Please keep us posted on your progress. I would be interested in how your project turns out.0
Bob,Review this previous thread regarding the rubber line that goes from the brake unit to the distribution block. Let me know if I can help.John Forkner0
- 109 Hudson 1916 - 1929
- 176 The Flathead Forum
