Front Axle seal 1939 Hudson 112
PaulButler
Administrator
Anyone have a part number for this at all?
If you can't find a valid part number for the seal you can get around that by measuring the old seal and/or the components. The era of the car means that those components were designed at worst in 1/16" increments, i.e. 3" or 3 1/16" or 3 1/4", a cheapy digital caliber will be fine for this job .You will find the seal is an off the shelf item and the bearing supply will be able to identify it from the sizes.0
Thanks both ; appreciate the help & advice0
I have NAPA
listed also
16246
- 97 Essex Super 6
