Starter ID needed
What does Auto-Lite MDF 6012 8 K fit?
Thanks
Don
Thanks
Don
I've found it as fitting a 1956 Hornet with Hydra-Matic0
Paul
308 or V8? (or does it matter?)
That starter is a 12 volt model for a 1956 Hudson series 60 with hydramatic. This is the only vehicle it was listed for. Your starter was made in August of 1955. Dosen't matter what engine .0
So, in theory, this should work fine a 53 Hornet w/Hydramatic that has been converted to 12 volt?
Ken
Can I switch out Bendix's from original starter to solve that problem? That seems like a PITA. I had a guy in Germany call me looking for a 12 volt starter for a 308. Maybe you know him....Marcel Krieg. I have a couple of these from a 56 but don't want to send it if is going to not work.
THE STARTER YOUR TALKING ABOUT WILL NOT WORK ON A 48 TO 54 HUDSON 6 AS THE CRANK SHAFT IS 1/2 SHORTER ON THE STARTER YOUR TALKING ABOUT THE 55 56 HUDSON CRANK IS SHORTER0
- 112 Hudson 1916 - 1929
