Advice needed: installing front wheel grease seal
It's a holiday weekend so when I realized I needed a front grease seal, I contacted a nearby Hudson friend. He obliged, with a pair of NOS seals.
However, the seals seem a hard. Close inspection seems to indicate they're either tightly-packed felt, or the suede side of leather. Seems like they ought to be a bit more pliable. Any suggestions for making them so (soak in oil, for example?). Or am I foolish to install old NOS seals?
Neats foot oil soak if leather0
I'm more impressed you had a nearby Hudson friend that had some seals as well Jon!0
Surely someone makes an elastomer late seal. I even buy those for my 1931 Franklin ??? All you need is inside, outside and thickness.
Jon,
If you seen a seal leak seals grease may have went onto your lining. If so, use CRC Brakeleen or similar then rinse.
I suggest clean & repack your wheel brgs while apart then soak & install your NOS Seals without concern since wheel bearing Grease is thicker then chassis lube..
- 103 Hudson 1916 - 1929
- 18 Upcoming Events
- 90 Essex Super 6
- 28.5K HUDSON
- 557 "How To" - Skills, mechanical and other wise
- 992 Street Rods
- 172 The Flathead Forum
- 77 Hudson 8
- 597 Vehicles
