Auto trans in a 47??? Does it fit?
thekid1950
in Street Rods
Trying to get some feedback & tips.....for an auto trans in a 47 four door
Thanks
You might want to give a bit more information. Is it now a six, or an eight? Are you sticking with the original 212 cid or switching to another engine?
My car has a 308 with a standard overdrive transmission. I'd like to go with an automatic0
With a 308, you have already moved the radiator as far forward as you can. That limits your space. I don't think a HydraMatic of Hudson vintage would fit.. maybe someone has done it??0
I don't think a fifties Hydramatic is any longer than an overdrive tranny, but the floor pan may have to be modified a bit to accommodate the bulkier Hydramatic.0
I have seen adds for adapters to put GM automatics on 308 Hudson engines. I think Wilcap makes them.0
A beefed up 2004R is smaller than a lot of OD trans and would probably fit better than say a 700R4. If you are going to jump to an auto then go with an OD trans.0
- 103 Hudson 1916 - 1929
- 90 Essex Super 6
- 28.5K HUDSON
- 558 "How To" - Skills, mechanical and other wise
- 992 Street Rods
- 172 The Flathead Forum
- 77 Hudson 8
- 597 Vehicles
