locked trunk stepdown
I found a small screw under the lock, loose it and take the lock out and put in a screwdriver and turn around, open! A small metalbar that connect the lock to the lockmechanism had fallen of.0
That'll do it.0
With a stepdown (you did not say what your car is) you can remove the back seat and gain access to the trunk.0
- 109 Hudson 1916 - 1929
- 176 The Flathead Forum
