6 volt tachometer
Westach should have what you need: http://www.westach.com/products/6 VOLT GAUGES/index.phpI believe they can custom make a 6 cylinder gauge0
You can find 6 volt ones but finding one for a 6 cylinder engine is harder !!!!. 4: yes; 8: yes; 6: no and most have a 3500 RPM limit.
Good luck; what you need is a SUN w/ a rebuilt 6 volt + sending unit. Harder~~~
If you find a sun transmitter the voltage probably won't matter since you'll most likely have to convert it to solid state. When they do the conversion they can make a 12v unit into 6v to work with the right head. Williamson's Instruments (http://www.williamsons.com/Tachometers.php) can do the conversions.0
Thanks Gentlemen, I will dig a little deaper0
- 112 Hudson 1916 - 1929
