Hudson Jet 3 speed overdrive transmission set up - $250
dbarrett
Hudson Jet 3 speed overdrive transmission set up. Includes bell housing, clutch/pressure plate, transmission, throw out bearing, driveshaft and miscellaneous parts. Includes a core starter that should be rebuidable. Also includes some new bearings/seals. Includes all parts pictured and also may have some more bolts/hardware that I will include if I can locate. Missing flywheel and some bolts/hardware. $250 for everything pictured. Must pick up in Blum, TX or my son could possibly deliver to the
Dallas/Fort Worth or Austin/Waco areas. My son will be in St. Louis, MO
(Fenton) on September 16 and 17 and Tulsa, OK on September 18. He can
deliver the transmission/parts for free at either city or along an I35 to I40
to I44 route from Fort Worth to st. Louis. Thanks, David
Most of transmission set up has been sold (kick down switch, overdrive wiring harness, relay and speedometer cable and transmission and bearings/seals are spoken for). I will separate the remaining parts so if you see anything you need please let me know. Thanks, David
Transmission and all parts have been sold, thanks David.
- 115 Hudson 1916 - 1929
