Tranmission oil 53 hornet
billbateson
Hi
I would appreciate help with the type of oil to put in a 53 Hornet hydramatic transmission.
Bill
Bill
Dexron is the common replacement today, look for Dexron III equivalent, or type F if you can find0
Sorry, I'm assuming hydromatic0
Thanks David,
It is Hydromatic.
Not sure of the equivalent to Dexron is in Australia but will look into it.
Regards
Bill B
Hi again David,
Found it online, Castrol have a Dex 111 so will look around locally for it.
Many Thanks
It's used in most all late GM vehicles so should be readily available0
Dexron for Hydramatic, and type F for Borg Warner.0
- 104 Essex Super 6
