I've been told this is a hudson HeadLamp, does it look familiar to you guys?
Looking to restore it and wanted guidance about going about it without causing damage. Any help appreciated
As Jon indicates, be watchful/careful - The senior 1938 Hudsons had different headlight buckets than did the 'Terraplane' (112) models. The senior Hudson buckets attached to the fenders had 'teardrop' lenses (as Jon indicates), while the 112 buckets attached to the grille mounting surface, and had round glass - very obvious if you do research and look at photos.
I also put together an instruction (.pdf) a few years ago, on building/rebuilding '39 headlights, which also applies to the '38 112 models as well - (Look in my later post (below) for the Headlight Bucket Guide) -
Jon B said:Not sure if '38 Terraplane and "112" headlamp units were identical; probably different in some way.
Actually, the only difference are in the mounts - stamped metal in '38, pot metal in '39 - totally different. The 'buckets' & internals (light, reflectors, mounting hardware for the reflectors, etc.) are exactly the same.
1938 112 headlight mounts -
1939 Hudson 112 headlight mounts -
david1956 said:I like the news about 38 Terraplane headlights , thank you to all who responded ! NOW , my Hudson is a 1938 model 81 with sealed beam bulbs in a Housing that bolts directly to the nose of the car on left an right side . They attach as the side panels start to show the vented or slotted strip side panels of the engine bay . Do I have the correct headlamps for this car ?
Show us a side view, back view, mounting view...
david1956 said:Thanks , I kinda thought that, I wasn't around in the 30s an 40s . Headlamps are just the start of my questions , more to come each an everyday . I'm just Terraplanning !
You might post pictures of the light buckets (from other angles), just to be sure. That 'modified' bucket just doesn't look right to me...
Also, when in doubt, take a good look at the parts manuals, & the 'Butler Book'.
What bothered me is what looks to be a 'lip' at the top of the bucket, just behind the rim holding the lens/sealed beam headlight in place.
It looks as if the bucket diameter has been modified (bent over, hammered-in?) at the top, to fit the (smaller(?)) rim and lens?
Advise: If you were 'set' on getting back to original or 'original looking' headlamps (quartz-halogen or LED, as Jon indicates) - I would set it as a 'long term' goal, and keep those headlamps in place until you have accumulated the parts and pieces to do it.
And, take notes from my Headlight Buckets Guide for the parts necessary - (See the attached .pdf file) -
Maybe a senior Hudson - not from a 112 (neither year, 1938 or 1939)…
