WANTED: Hornet Twin H trunk emblem
iceblade10
I am looking for a chrome Twin H-Power trunk emblem suitable for a 54 Hornet. Thank you.
Try EBay I think there are a couple there. NOT mine0
Try Frank Dluhy in NY. His number is in the roster.0
I found one on eBay! Thanks!0
See if Steve Trout is still making them.0
What size mounting pins does he use. I bought a repro that had 1/8 pins and paid a lot of money and I didn't want to re drill the trunk lid.so found a original one. Ray
Bought mine from Steve, unchromed. did the chrome work myself. It looks great....0
Curious about 'doing the chrome work yourself' ??0
Kenny-
Sent you a PM.0 -
Keep in mind that you'll need to purchase heaters and a rectifier if you don't have them which can run another $200-$1,500 depending on your needs. Some folks simply use a battery charger but I opted for the 25 amp rectifier when I was using their copy-cad kit so that I would have enough juice to do medium-sized parts and eventually move to chrome. Caswell has excellent products and their kits are great after just a little practice.Ken U-Tx said:
You can get a Caswell triple plating kit for small parts for around $500. If you have enough parts to plate at a given cost per part, then you might break even or save some money. Your first few pieces may not be of "show quality" as there definitely is a learning curve involved.RichardD said:Curious about 'doing the chrome work yourself' ??0 -
Do not get carried away folks, when I said that I did it myself I was talking about that I have access to a chrome shop and went to the shop and cleaned and ran the part. I understand the process but would never consider plating a "DIY" project. As a young man I worked in my Dad's tire recapping business--just the same, I understand the process but would never consider restoring a tire from scratch....0
- 590 "How To" - Skills, mechanical and other wise
