Hudson 6 Bolt Pumpkins
actually this should be 6-bolt ring gears.0
The pumpkin setup I acquired is a 3-5/9. it's obviously for an earlier car, but when I look in the parts book, that ratio was for a "service" vehicle. I don't know what that means. I'll have to check axle diameters further when the weather breaks. But I am hoping to run that ratio behind an overdrive to make a 212CID road car. Could be a pretty cool set up for going the distance, all be it under powered - I can live with that!
Allan, you might give Nelson a ring, he might know.
you may be right Ken, but who wants to run 60 mph? I want to run 75 giving me 2200 RPM - right in the power curve (on flat ground that is). Lots to think about in the coming months.0
Allan, you'd be over-geared with the 3 5/9 and OD. Tried it on my Hornet when I put the OD in it, and it was too "tall." As mentioned above, you'd be considerably below the optimum RPM. I'd run it with the 3 5/9 and no OD.0
what is the final drive with overdrive and a 4.11 vs. 4.59 as the factory would have done?0
Isn't that a simple matter of calculation? 4.11 rotations after an overdrive ratio of .7 (I think). It would be 4.11 rotations at the rear axle in conventional 3rd gear (1:1 ratio). Multiply that by .7 and you get 2.88 rotations per revolution of the engine. It would be 3.21 for the 4-5/9" (standard) ring and pinion, in OD. And, of course, 4.59 in conventional 3rd with no overdrive. Going in the opposite direction, if you glommed onto a 3-5/9 gearset, your rear axle would turn 2.128 times for every revolution of the engine.
Keep in mind that math is not my strongest suit.
Awesome guys, thanks.0
- 120 Hudson 1916 - 1929
- 612 Vehicles
